Here's some more pictures, this time the tub interior and the underneath:
The passenger side has a fiberglass cloth overlay under the outermost seat track. Battery was relocated behind the passenger seat:
Area under drivers seat is intact (Just really dirty!)
Plus, there's this wooden block assembly where a roll bar could go, but it's not large enough to hold one and it's only on the driver's side.
Prior owner was big on reinforcing, or bolts had pulled through fiberglass previously:
One of the seatbelts has a diamond plate square above and below with the seatbelt bolt running through:
Also reinforced in several over places with steel bars above and below (Little trash can has two bolts holding it in place (sigh):
Floor is intact on drivers side, but worn through the gelcoat, much of the car has been repainted.
Now underneath:
The hourglass wood piece stops at a piece of angle iron that is welded on to the rear of the bottom of the front end torsion housing:
However, there is another piece of wood (Masonite?) that is bolted underneath it so it is double thick in that area.
Here's the view from above under the trunk. You can see the hourglass board was cut off before it reached the angle iron, and held up by the board underneath:
This is where the front bumper bolts come up through both boards:
Here's another shot from underneath:
Here's looking back towards the rear of the buggy from where that Masonite board stops. You can see the reinforcement bars matching the ones on the top side:
Here's where the rear cage mounts, and where a gloppy repair to the gas tank was attempted:
The rear torsion bar is barely hanging on (Obviously had a rough life!)
Passenger side is not much better
Passenger side cage
Drivers side cage
Front bumper may be original? It has the same exact welds as the rear:
That's the pictures I took this morning. Please let me know if you'd like to see something that I might have missed and I'll take some more. It may take a little time to take more pictures, however. I've moved the buggies around today. I have a three car garage that will hold four buggies. Thankfully, I have a great friendship with my ex who lives only two miles away. She's keeping two of them on a temporary basis.
