Hello friends!
I've introduced myself in another post. Below are some pictures of the frame build so far. The frame is a 1971 bug which was in good shape when I acquired it.
[*] Frame was scuffed and old seam sealer removed
[*] POR 15 applied to the top of the frame and seams rescuffed, seam sealer applied
[*] Bottom was scuffed, seam sealer applied
[*] 2 coats of Raptorliner was applied to the bottom of the frame
[*] Rear arms, spindles were powder coated
[*] Rear arms had bushings removed and new bushings installed
[*] Axle hub was rebuilt with new bearings and seals, packed with synthetic grease
I realize POR 15 needs a topcoat if exposed to the sun, but I will be applying sound dampening material to the top of the frame, then carpet, so there will be no exposure to sunlight.
