My french Manx
Re: My french Manx
Looking good! getting closer!
Tow'd #1 (Hers)
Resorter #19-Fuscia (Hers)
Tow'd #2 (Ours)
Tow'd #1 (Hers)
Tow'd #2 (Ours)
Re: My french Manx
Thanksmanxvair wrote:Looking good! getting closer!
Re: My french Manx
I’m happy the engine turn
I must look the carburator
[youtube]http://www.youtube.com/watch?v=rzcs8F3NV48[/youtube]
Re: My french Manx
Your photo didn't post. you say look at carb. if so: be sure ,if you have electric idle circuit it is powered and working. If electric idle circuit is not operating: your vw motor will never idle.
- Mike-Presley
Re: My french Manx
Nicely done and sounds good.
Re: My french Manx
For the carburator I must look the synchronisation first
Yesterday I drive it in the garden
[youtube]http://www.youtube.com/watch?v=g0WhQAehpRU[/youtube]
Re: My french Manx
sorry, your photo still not posting. I was unaware you have 2 carbs. I only use single carb. my understanding of syncing carbs is to take your time to get it correct. It is also my understanding that temperature and humidity changes affect the tuning. in my climate day to day changes and seasonal climate conditions would require greater attention and tuning for 2 carbs: which is the main reason I use single carb. good luck and have fun with the tuning.
Re: My french Manx
Thank youlastmanx wrote:sorry, your photo still not posting. I was unaware you have 2 carbs. I only use single carb. my understanding of syncing carbs is to take your time to get it correct. It is also my understanding that temperature and humidity changes affect the tuning. in my climate day to day changes and seasonal climate conditions would require greater attention and tuning for 2 carbs: which is the main reason I use single carb. good luck and have fun with the tuning.
I choose two carb because I prefer the appearance.
not easy to adjust but I already have weber 44 on the karmann ghia and I make the settings by testing on road
Re: My french Manx
You prefer the appearance . I think that is the best reason to have them. So you must be driving it now. How do you like it?
Re: My french Manx
That is great. Ohh it must be hard having to wait, until you get to drive it on the road. I would like to advise you: on the road your Buggy will attract a lot of attention : so keep focused on your driving, bring a passenger with you who can wave back at admires that will be smiling and pointing at you. This may sound silly but it does happen. Here in USA I get the "thumbs up" hand signal often from people as we drive along. But most importantly enjoy the fun of driving on the road a buggy you built. I trust all the nuts and bolts are tight
Re: My french Manx
I don't know if I could wait either, but good luck with your inspections. Looking forward to your report on how the driving goes.
Tow'd #1 (Hers)
Tow'd #2 (Ours)
Tow'd #1 (Hers)
Tow'd #2 (Ours)
Re: My french Manx
Thank you for your post
I got my technical control and I can now ride on the roads
this winter I am going to make improvements and thanks to road tests I will be able to test.
thank you all for your posts and I will continue to put pictures
[youtube]http://www.youtube.com/watch?v=ZbXVIJVjkSY[/youtube]
