Subaru swaps
- RedBaronofRedBud
Subaru swaps
I didnt know if this had been explored or not, but Im interested in what is all involved in a Subaru swap. Any and all knowledge is gratefully accepted and encouraged.
Tim
Tim
Tom-Kathleen
Re: Subaru swaps
I can help. Which buggy are you putting it in? Tom
- RedBaronofRedBud
Re: Subaru swaps
Actually, it's going into our bus, but the concept is the same.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Tim and Barb Byrnes
#4236
Team Kermit
Long Haul League
ECVW 14
S2B 15
BTTB 15
Join us in St Louis for Manx in the Middle 2017!!!
Im not a complete idiot...there are pieces missing.
#4236
Team Kermit
Long Haul League
ECVW 14
S2B 15
BTTB 15
Tom-Kathleen
Re: Subaru swaps
I have never done a bus conversion. I would start here - https://smallcar.com/conversions/type-2 ... sions.html . Buy an engine from Outfront http://www.outfrontmotorsports.com/homepage.htm or get a local car. Get a transaxle from here - http://www.subarugears.com/ or http://ranchotransaxles.com/rancho-suba ... d-vanagon/ and a "black box" http://www.subarugears.com/subatronics/index.html if you decide to go with the original Subaru ECU.
With those parts in hand, the only fabrication you would have to do it the radiator and radiator mounts. A lot less than we had to do to convert the Manxter. Good luck! Tom
- RedBaronofRedBud
Re: Subaru swaps
Thank you, Tom! I appreciate it!
Tim
Tim
Tom-Kathleen
Re: Subaru swaps
You can still use the Bus transaxle with an adaptor, but the gearing will be high for the Subaru engine. A money saver, but not the best way to use the engine. Tom
- RedBaronofRedBud
Re: Subaru swaps
I have acquired a 2007 Impreza with a 2.5 and 5sp trans. I plan on putting them both into the bus.
Tim
Tim
Tom-Kathleen
Re: Subaru swaps
That should be a great combination. You will need parts from Subaru Gears. Tom
- RedBaronofRedBud
Re: Subaru swaps
Yes, Im sure of that, but I dont know what will be needed. I suppose I should talk with Toddles
Tom-Kathleen
Re: Subaru swaps
If you need help modifying the transaxle housing from 4WD to 2WD, let me know and I can help with that. Tom
Re: Subaru swaps
Do share your experiences please, RedBaron. I'd be very interested to find out how you did it and what your thoughts are.Tom-Kathleen wrote: ↑Tue Sep 19, 2017 9:59 pm If you need help modifying the transaxle housing from 4WD to 2WD, let me know and I can help with that. Tom
Tom-Kathleen
Re: Subaru swaps
I have a Bridgeport milling machine at my house. I have never modified a Suby transaxle case, but tell me where to cut it and I am sure I could do it. Tom
