We are finally getting our engine built. The builder wants to use CB performance Solex dual 34 kit with the electric choke. His question and mine is will this carb kit fit under a Siggy Manx? If it matters we will also be using the sidewinder exhaust. Anyone else using this kit?
Gary
Dual Solex 34 installed in a Siggy Manx?
eurekagary
Re: Dual Solex 34 installed in a Siggy Manx?
If on a vw pan and motor in stock position most anything will fit. Kadrons,off set manifolds with idf's,even ida's. If carbs fit in stock bug engine bay will fit Manx body. Cross linkage like Kadron style works best. The hex bar type has trouble missing body,Berg type work too and cross cable is best of all. IMO.
