Bud's Manx Restoration
Re: Bud's Manx Restoration
Post by rzeller »
joescoolcustoms wrote:Nice! Also, do I see a curved, copper Hurst?
Yes Joe, you do :lol: I've had one for a number of years and it shows it's age (normal rub spots near the handle and by the boot). I am looking for an NOS or near-NOS one just like it. Will pay TOP dollar for the right shifter 8) Anyone "know a guy?"
Bud Zeller
Wilmington, NC
'68 Meyers Manx - M1996F826S
'66 VW Kombi Bus
'73 VW Thing
surfnc
Post by surfnc »
Update 2/23
Bud came up to help with the dash layout and some other things this week end. It was great to see Bud and his help was invaluable.
When I restore a buggy for myself it is relatively straight forward to set up the dash. When I am doing it for someone else, it makes it easier (for me anyway) to have them there to lay it out the way it will work best for them. It also gives them a chance to see it in person instead of by pictures over the internet.
Bud helped get the roll cage back in. We also got to have fun seeing what was behind the "Do Not Remove" cover on the seat belt retract assembly.
1068
It was also very helpful for Bud to come by because he caught the dash spacing issue before it went too far.
When the ABS dash was made into a fiberglass dash, it was made to be glassed to the dash or go under the dash. This means that the exposed top portion of the dash sticks into the passenger area about an 1 1/2" more than the ABS dash if you glass it directly to the hood. This does not cause a problem if you have no roll cage that was made to fit close to the original dash. Bud reminded me that this might be an issue. It was!
To correct this I needed to remove the 1 1/2" of the dash so it would fit inside the roll cage.
I marked it out on painters tape and taped off the cut line.
1069
Cut it with an oscillating tool. (Thanks for the idea Tom Thompson)
1073
You can see that the tool makes a straight cut without damaging the gel coat. A saw or reciprocating blade tends to beat up the surrounding area and can stress or chip the paint and/or gel coat.
1070
So with the dash removed I could check the fit of the modified dash.
Here is the remains of the dash still on the hood, I was then able to confirm that the cut dash will fit in front of the cage.
1076
1075
Now to reglass the shortened dash and move on to more wiring.
Vince
surfnc
Post by surfnc »
Temporarily installed dash to check clearance.
1078
It has about 1/2". Will work fine. I did have to shave a bit more off to get it to fit.
Now on to glassing
Vince
abgiles
Post by abgiles »
Must have been quite nerve racking to have to cut off the newly glassed dash. Expectedly though, it looks like it was an even, clean cut! Good catch on that!
(Gunther) Manx 2 # A0202A035E
Tow'dster # TF530G913S
Club Member # 4436
Mike1991
Post by Mike1991 »
Looks great. Will the windshield wiper motor clear the exiting gauges now you have narrowed the dash front to back?
surfnc
Post by surfnc »
Brian,
Not too bad to cut it. The good thing about fiberglass is that you can usually cut/sand and start over.
Mike,
It will clear the 68 speedo. I may have to move the "vibrator" on the fuel gauge. Since the original dash had the same spacing it really should not affect it.
Update 2/24
I glassed the dash back on yesterday and it fits fine now. Today I prepped the rear of the dash to mount the speedo. I drilled shallow holes in the back of the dash and used resin thickened with cabosil to bond some stainless steel bolts to the dash. (can see them at 3 and 9 o'clock of speedo hole) Once it cures I will bolt the speedo in.
1081
I have used this method on the last 4 buggies I have done, it has worked well and hides the bolt/screw.
Vince
Post by joescoolcustoms »
Nice work as always Vince!
As another wiper mechanism fit solution tip, cut off the two mounting tabs smooth on the gauge housing, and slip in the stock speedo from the rear. To hold it in place, use a radiator style hose clamp pushed up against the fiberglass with 4 to 6 pieces of metal between the housing and hose clamp to keep the thin hose clamp from slipping through the cut hole, keeping the gauge tight. This will gain about 1/2 inch more clearance. Not a lot, but most times just enough.
Post by manxvair »
When you have a chance Vince, can you post a picture of the wiper assembly you'll be using.
Tow'd #1 (Hers)
Resorter #19-Fuscia (Hers)
Tow'd #2 (Ours)
surfnc
Post by surfnc »
Thanks Joe!
Do you have a picture of your process? How far does the face of the speedo stick out of the dash?
surfnc
Post by surfnc »
Sure Mike, it is a 67 12 volt assy, will post pics tomorrow.
surfnc wrote:Thanks Joe!
Not earth shattering clearance, but a touch more if it is crowded right up against the wiper movement.
1082
Plus, it will match rear mounted accessory gauges decently.
(Can hardly wait to bust that buggy out of storage in another month!!!)
Post by rzeller »
Joe, how and what keeps the gauge from "falling" through the front opening? I know you mentioned something about metal on the back but I'm having a hard time visualizing that.
Bud
Bud Zeller
Wilmington, NC
'66 VW Kombi Bus
'73 VW Thing
Bud
Just simple small pieces of sheet metal cut into strips, then bent at a 90* angle. One end tucked under the hose clamp, the other against the front side of the fiberglass, or the dash metal plaque.
1083
1084
Post by rzeller »
Gotcha. Thanks. I'm a visual learner - I love pictures :)
Bud Zeller
Wilmington, NC
'66 VW Kombi Bus
'73 VW Thing
surfnc
Post by surfnc »
Here you go Mike.
1085
