Manx Ult. Hadley Vair
Our recently purchased Manx Utility has a Hadley Corvair conversion. It uses type 1 suspension with Corvair running gear The engine is tired and the trans is a three speed. We're look'n at an up-grade. Has anyone experienced working on a Hadley? I want to pull the Corvair. It looks like the Hadley kit and the Corvair stuff needs to come out as a package?
I have one buried in the garage.... I took it off a parts buggy. The original installation required cutting off the VW pan frame horns. It might be quite a bit of work to return such a pan to VW transmission. The Hadley conversion seems like a nice period piece. Why not keep it? Maybe convert it to a 4 speed, or even an automatic?
If you decide to stay with the Corvair drivetrain, I believe there is a Corvair specialist shop in San Jose: Mel Raven of M & J'S VAIR Mart 1858 Almaden Road Suite 6, San Jose, CA 95125 (408) 267-8164. You should also buy a copy of Keep Your Corvair Alive from Clark's. Its out of print, but they still have copies. Its the best book for explaining what can and should be done to a Corvair. http://www.corvair.com/user-cgi/catalog ... N&page=249
Nelson ... I picked up both books awhile back they're great. I also just picked up a sweet sand rail, from a yard sale, that is Vair powered. The engine is a tricked out 140HP with all the Edelbrock stuff and it came with two 4 speeds. The folks also have, 4 SALE, a great looking "Manx Wana-B" buggy with a 1776 that is very road / trail worthy. Anyway it looks like we have a winter project ... after Lone Pine. Mark & Carol
It'll fly with that engine. Another variation I've seen with Corvair drivetrain in buggies is similar to what Transvair used to do with later busses. You'd need to install VW IRS semi-trailing arms. You splice together half the Corvair swingaxle with a VW IRS half axle. You leave the Corvair U-joint on the inner end of the half axles but you have a VW CV joint on the outer end, to connect with the VW stub axles. Or there is an adapter Clark's sells which uses CVs at both ends. http://www.corvair.com/user-cgi/catalog ... ge=OTTO-44 Corvair swingaxle bearings aren't very good to begin with and are hard to get now. Replacing the whole rear suspension with VW IRS parts would improve reliability and handling.
The Hadley Transvair set up is an interesting concept with it's design. should work for our road needs. I don't think it will be ready for Lone Pine but a spring run is our goal. It will be fun to bring it to an event for a coming out ... The folks that sold us the vair stuff also have, 4 SALE, a great looking "Manx Wana-B" buggy with a 1776 that is very road / trail worthy if our barn wasn't run'th over ... Mark & Carol
Here's a picture off a Samba ad of someone who has adapted a Corvair transaxle to a VW IRS suspension. I'm not sure why he mounted the transaxle so far aft though. On a Transvair the front of the transaxl;e bumps right up against the torsion housing. http://www.thesamba.com/vw/classifieds/ ... ?id=650694
Tom-Szwajkos
Re: Manx Ult. Hadley Vair
I am looking to convert my Manx with the Hadley Transvair Kit from the Corvair swing axles to cv joints or utilizing the late model Corvair IRS components. I want to maintain the Chevy 4 3/4" 5 bolt lug pattern. I cannot seem to find a long enough stub axle for this application. I looked at the Chevy S10 bearing assembly but the stock and aftermarket stub axles are too short to fit. The Transvair kit custom arm assembly has the 3" long tube between the outer flange which mounts the swing axle and the other end which mounts to the VW spring plate. I looked at the 68 Corvair stub axle assembly but it looks too short. Any ideas?
