Adjustable irs spring plates
YellowSafari
Post by YellowSafari »
So is there any reason SwayAway adjustable spring plates shouldn't be used on an off road buggy ?
Re: Adjustable irs spring plates
I have been using adjustable springs on my buggies for many years without any problems. A lot easier to adjust then removing and resetting the torsion bars.
Mike-Presley
Post by Mike-Presley »
I’ve got friends who have been using them for years with no problems. You might consider a torsion adjuster also if you’re at that point in a build. I went to 3x3 arms and torsion adjuster. Setting the droop was real nice.
GotManx
Post by GotManx »
I've also used adjustable spring plates with no issues. I prefer the center torsion adjuster, but that is a lot more fabrication work.
YellowSafari
Thanks for the replies. I mentioned I was going to shorter torsion bars, and adjustable spring plates, and some one piped up with not to use them on an off road vehicle. When asked why they couldn't back it up.
Continuing as planned 8)
We swapped out the longer torsion bars on our off-road buggy for the shorter ones some years ago. While we have not had any issues, I have also been told that the shorter bars tend to fail more in one way or another when used in any significant off-road capacity due to their repeated greater twist over that shorter length.
