Do you use a master fuse or fuseable link
eurekagary
Post by eurekagary »
I am done with the wiring, but didn't install the 50 amp master fuse yet. Do I need it? I know it for a catastrophic short, but I am having a hard time finding a good spot to place one, plus I don't like my options.
Thanks
Gary
Re: Do you use a master fuse or fuseable link
We run a 12-curcuit Painless Wiring fuse block (which has a fuse to the coil), but no "Master Fuse" for the overall electrical system. Each circuit has its own fuse. We also use a battery cut-off to disconnect the battery when not in use.
lastmanx
Post by lastmanx »
you don't need it. vw factory harness never had it.i have built many buggies and wire harness,and all work fine today without it. a battery cut off is nice fail safe,but I never used one.if you wired correctly don't worry buggy on.
