Surprising Ride/Handling Difference
Don Giovanoni
I have an adjustable front beam and SAW adjustable IRS spring plates on my Siggy. I lowered the front beam during the original build to add some "rake". I did add a caster shim under the lower tube on the front beam. That is how I ran it for the last couple years, seemed Ok. During the holidays I noticed that the distance in the front between the tire and front fender was less than in the rear. I decided to see what the overall look would be if I raised the front end some to even out the gaps, so I did it. Finally got a warm(er) day to take it out for a ride. Wow! The ride was considerably better as well as the steering and stability overall. There is a major improvement, really noticeable. When the weather breaks I will get the alignment checked (although during my test drive I could let go of the wheel and it tracked perfectly straight) as I bought the "lifetime" alignment from the local Firestone store. I am sure they are sorry as it will be my 3rd time back. Hope to see everyone at Funfest in May.
[QUOTE="Don Giovanoni"]I have an adjustable front beam and SAW adjustable IRS spring plates on my Siggy. I lowered the front beam during the original build to add some "rake". I did add a caster shim under the lower tube on the front beam. That is how I ran it for the last couple years, seemed Ok. During the holidays I noticed that the distance in the front between the tire and front fender was less than in the rear. I decided to see what the overall look would be if I raised the front end some to even out the gaps, so I did it. Finally got a warm(er) day to take it out for a ride. Wow! The ride was considerably better as well as the steering and stability overall. There is a major improvement, really noticeable. When the weather breaks I will get the alignment checked (although during my test drive I could let go of the wheel and it tracked perfectly straight) as I bought the "lifetime" alignment from the local Firestone store. I am sure they are sorry as it will be my 3rd time back. Hope to see everyone at Funfest in May.[/QUOTE] Nice work Don :rock: I love reading about buggy handling improvement resullts. IMO the setting up of a new built buggy is often overlooked. Anyone remember the old Manx Mania features on cutting torsion springs & putting BBQ lighter fluid in stock shocks??? It works bloody well ol chaps!!
