Trial fitting and marking the position.
Since the body to chassis bolts are now hidden, it needs another way to bolt up to the chassis. Flush mounted threaded inserts. I start with a simple 1 3/4 inch long threaded Hex connecting bolt, and turn the hex off to make it round.
Then cut them in half giving a 7/8 inch long threaded slug.
Drill the marked holes slightly bigger than the OD of the threaded slug. I used a standard 60* counter sink bit to bevel the hole for better welding without ruining the threads in the slug.
Use a magnet to flush hold the threaded slug in the hole. (Picture of the 60* standard counter sink bit)
The beveled hole makes a nice finish weld with very little clean up needed to give a flat surface for the Nerf Bar to anchor to.
Finished side rails, trimmed to length, custom fitted for the front attachment onto the Napoleons hat, Sunken body/chassis bolts, flush threaded mounts for the Nerf Bars.
A lot of detail time spent on just the side rails, but time very well spent. Friday will be the day the chassis takes shape.
