Leaking sending unit
- Mike-Presley
Anybody have a recommendation on how to seal a leaky electric fuel sending unit. It's a new VDO sender but when I fill the tank up it pools around the sender. My hood is a pain to get off so I haven't actually looked at it yet. I have reached under the hood and splashed in the gas though. It's a stock tank.
Hi, I put two gaskets on my new sender, the way they made it the sender hit the tank before it sealed on the gasket.
Note how deep the sender is on the left where the gasket sits that why I put two gaskets, works great.
1969 Sand Rover T pickup
1973 Thing / Yorba Linda,Ca.
- Mike-Presley
I had one like on the left but it didn't check out on the bench. It had erratic readings. Now I am using one like on the right. It reads good on the bench and in the buggy. I'll pull the hood Sunday and go from there. Thanks
- Mike-Presley
Pulled the hood today. My sending unit came with crappy little lock washers only. Threw them away and used some neoprene washers with thin flat washers. Had to steal from gas from my red gas station in the driveway to top off the tank. No leaks, hood is on and no leaks after a short run around town.
