the 3 inch body lift
if your building your buggy for off road use consider the 3 inch body lift. it will give great ground clearance by allowing large diameter tires. I use 15 inch rims front tire is a p225/75 R radial tire
body clearance is fine and never rubs. the rear is a 33x10.5 tire 15 inch rim using a swing axle trans
the body never rubs even fully loaded with equipment off road. the body ground clearance is 12 inches in front
13 inches rear the suspension is stock no adjusters. an added benefit is easy access to your tyrods steer box brake master cly. and bottom gas tank hose. same in rear easy access to adjust clutch and engine needs.
