windshield bracket
windshield bracket
does anyone know who sells or makes a windshield bracket so i dont have to drill into this brand new pretty frame from winnie. any pros and cons on the matter.thanks .....''wildthing''
tim morgan
You can get them through Dino,,He is most likely the one that makes the windshield for Bruce,,,,,Give him a call,,Great guy..
tim morgan
There is also http://berrienbuggy.comThey sell the steering column support kit with the windshield kit,,
They're really easy to make or you can buy them here... http://cgi.ebay.com/ebaymotors/MANX-DUN ... ccessories ...or just use some M8 bolts with dome heads. The Berrien parts require drilling the frame.
tim morgan
[QUOTE="Manxdavid;14769"]They're really easy to make or you can buy them here... http://cgi.ebay.com/ebaymotors/MANX-DUN ... ccessories ...or just use some M8 bolts with dome heads. The Berrien parts require drilling the frame.[/QUOTE]Hay Dave your right,,I bought a brace and I all ready had the windshield mounting kit from Dino,So i really never looked at them or the derections,,Thanks,,,My Bad.......
[quote="TMc2548;14771"]I came up with a good way to mount the windshield that actually makes mounting a one man job. I used 3/8" studs TIG welded to 5/8" flat stock. Mount the brackets to the hood and slide the windshield down over them. Pics available on request.[/quote] Tom, Too bad there's not a simple way to get a patent. The guy on ebay took your idea and is selling them for $45 a set. Besides not having to drill holes in the windshield frame and making the windshield more secure, what I like is how much easier it is to install the windshield. No more holding the windshield with one hand while twisting my other arm backward to reach up behind the dash to start the nut on the top bolt which barely protrudes inside the dash frame, because the head of the bolt is in the windshield frame leg, which splays outward until the bolts are tightened. With your brackets you just install them, start the nuts, slip the windshield in place and tighten the nuts. If you can't get the money, at least you deserve the credit. Good on ya.
