6volt to 12volt starter
captron945
The short story is I need to replace the 6volt starter with a 12volt starter. The engine is installed. How do I remove the 6volt bushing without removing the engine?
captron945
6volt to 12volt
Will the autostick starter work with the 200mm flywheel??? I replaced the 180mm flywheel when I changed out the clutch.
captron945
6volt vs 12volt
Thanks, I will look at the autostick starter this weekend. Something else has me puzzeled. My buggy has a 12v battery. How can that work with a 6volt starter. Is there anything else I should be looking at. I also have an alternator w/regulator.
captron945
6voly to 12volt
I got the autostick starter today. NO shaft/bushing. I installed the starter and it works great. Thanks for all your help. ron,
Montana-Manx
[QUOTE="Montana Manx;13569"]My buggy had a 6 volt starter in for 20 years with a 12 volt battery. I did change over to the 12 volt when I changed the flywheel and clutch with a new bushing to fit the 12 Volt. Also had to clearance the bell housing because on the 6 volt bell the bigger 12 volt flywheel did not fit.[/QUOTE] Some people might not understand, but you have a swing axle tranny, which are configured for 6 volt systems, including flywheel.
Re: 6volt to 12volt starter
Easy solution.....buy one of these 12V starters that is self supporting and has a 6V gear on it. No need to grind or clearance. Just did this and it solves any starting issues you might have.
http://www.kustom1warehouse.net/Imi_hig ... arter.html
ManxManiac
In the last 6 months or so, I've bought about 6 of the "auto-stick" starters at O'Reilly's for friends & each time they were $39.99 plus $10.00 core!!! That's a great deal... hope you got a deal too!!!
Michael Cates
ManxManiac
#958
Ventura, CA
Original Meyers Manx "Xena"
M1609C8S22
ManxManiac
#958
Ventura, CA
M1609C8S22
hillmotorsports
Michael
Could you share the particulars of what you asked for?
Year, model?
I'm sure others would appreciate the info!
Thanks
Year, model?
Thanks
Rosemarie and Paul Hill
Morrisburg, Ontario
Canada
613 330 4862
Member #4502
Morrisburg, Ontario
Canada
613 330 4862
Member #4502
