I recently built a new motor for our Manxter and decided to
use a Kennedy Stage 1 clutch.
After taking the buggy for a spin, I immediately noticed how stiff the
new clutch was. After driving it to work on the back roads I realized I wasn’t
quite happy with the new clutch. Not only was my leg tired but the ball of my
foot was sore. I could only imagine the added pressure on the clutch
cable.
This could lead to the
cable breaking.
Something had to been done.
I remembered reading an article in Hot VW’s about Brazilian
VW’s having a long clutch release arm. After a lot of research I was able to
locate a source for these arms(NOS). These arms are 100mm long (compared to the
stock 73 mm) and fit early type 1 bug and type 2 bus transmissions that have a
16mm clutch shaft.
Installation
(with the engine out) is fairly easy. First, remove the clip locking the arm to
the shaft, slide the arm off the shaft, replace the arm and return spring with
the longer one, and replace the clip. Now just adjust the clutch cable and you
are ready to go. The added length on the clutch arm increases leverage and
reduces the pedal effort dramatically. This makes the Kennedy clutch now feel
like a stock one. The Manxter is a lot more fun to drive again and the wife is
happy too.
If anyone else is interested in one of these clutch arms, I
do have a few available.
Doran Dobranszky
Manxclub Member #761
