Flush Gas Cap Question
StanLove
Post by StanLove »
Could use some help, I would like to put a flush gas cap assembly on my signature manx. Im about to have my tank configured to Bruces specs. (Center and cut down to 2" per directions.) Would that still be the case for a flush cap assembly. I would like to put in a 9 bolt aircraft-style cap from McKenzies (Anaheim, CA). Im worried about distance from tank to hood. If anyone has done this I would greatly appreciate some direction. I have seen them on other Manx and they look great. Any pros or Cons would help. Thanks for your time Stan stanluv@aol.com
Siggymanx33
Post by Siggymanx33 »
Stan, Been there. I ended up using the Texas Manx tank that was pre welded with a bung and kept the original sender mounting hole. I needed a new tank and the price was pretty reasonable. I installed everything first and then took my measurements which included scribing a line from underneath (it can be reached) and drilling a pilot hole to start the process. I still needed to install 2" of fuel resistant radiator hose from the bung to the filler. Any slight mis measurments can be taken care of here. One other thing, when fitting the hood, be prepared to have to smash the passenger front corner of your gas tank to make the hood fit without damage to the gel coat. Do a search as we fully covered this when I went through it. EDIT: Here is that explanation http://www.meyersmanx.com/forums/showth ... light=bash Let's see some pictures of the project This is my 333rd post for #33.
Gary1719
gas cap
Post by Gary1719 »
Dave were did you get that cap. gary1719#
Siggymanx33
From Mc Kensies. Be prepared though they are a bit pricey.
Gary1719
web site
Post by Gary1719 »
do they have a web site. gary
Siggymanx33
http://www.mckenzies.com In a simple search, I couldn't find the door but I know it is in there catalog. I think it was $195 with the lock and $175 without.
Gary1719
cap
Post by Gary1719 »
okay i will check it out thanks.
Go to Google Images, type in "fuel fillers" then you can click on the one you like and find out where to get it.
Gary1719
google
Post by Gary1719 »
OKAY, thanks jerry.
