Manx I body on Berrien frame
Rick Leddon
Post by Rick Leddon »
I am planning on using a IRS Berrien Frame with a Manx I body. I have been told I need to use a lift kit. I like the vintage look and want to keep the lift to as little as possible. I think that will be a two inch lift. Can anyone give me advise and give me a lead where I can get a lift kit. I contacted Andy, who was recommended by Winnie, but he doesn't do a 2" lift anymore. Thanks Rick
fubar
Post by fubar »
If you search the forums there are some pretty cool home made lifts on stock pans using tubing and that plastic deck material. You could probably make one with basic power tools, but a band saw would help.
If you want it to look as much like stock as possible and still have the IRS components clear the battery box and spare tire well, you can have a tapered body lift made at a local fab shop relatively cheap. A tapered lift would give you about an inch of lift in the front and as much as you need in the rear. My friend had one made for his EMPI IMP so it would clear the sand tires, he sketched it up, brought the sketch to a local shop and in a week he had the lift kit. He had to drill the holes but it only cost him around $100 bucks. If you look closely at this pic you can see the lift kit. Image And it will take some abuse and come back for more. Image If you have anymore questions let me know and I will try to get some answers for you.
Old Manx Body on Berrien w/o lift
Here is an old thread that discussed mounting the rear torsion housing lower in relation to the Berrien frame. http://www.meyersmanx.com/forums/showthread.php?t=2580
Jon
built in lift kit
Post by Jon »
The Berrien chassis has a 1 1/2 lift all ready built into the frame.
My Berrien frame does not have a 1 1/2" lift built into it. My original Manx body will not fit on it with the IRS Suspension. My Berrien frame is one of the first they produced, maybe they made a change at some point.
