Mastercraft A/T Tires
louisb
Post by louisb »
Anyone running Mastercraft A/T tires on their buggy? If so how does it ride? What PSI are you running? And how is the noise on the highway?
Thanks,
--louis
BuggyBob
Post by BuggyBob »
Hey Loiue,
I run bfg a/t on my buggies. I run 12 psi in them except when towing, then I bump them up to 20 psi. I dont hear the noise from the tires because the wind is louder. You are more apt to hear the tire noise from a vehicle next to you than your tires.
louisb
Post by louisb »
Yeah BFGs were my first choice but they only make a 235/75-15 not a 235/70-15. It is only an inch difference but I am concerned about highway performance as I plan to do some long distance trips in the Manx. (I refuse to trailer it to Cali for the Manx Club Events.) Trans is a stock geared 4.12 SA with an 1835 motor. I want to be able to cruise at 70 mph comfortably without having to downshift at every hill. So I am trying to keep it under 28" for the rears. So far Mastercraft is one of the few companies that make that size and have a 14" tire as well (195/75-14 which is a 26" tire).
Thanks,
--louis
Tom-Szwajkos
Post by Tom-Szwajkos »
BF Goodrich web site #3 [url] [-]
avatar
Jun 22 10 5:46 PM
Member #295
The BF Goodrich web site is a great source for tire information. They have a tire chart shown below that is sourced from a tab on the bottom of the specific tire model under specs (click on more tab on the right for additional info) that provides you with tire sizes, recommended wheel width and overall diameter of the tires by size. This chart is for the Radial TA. There is also an off road tire section with some nice tires on it.
Technical Specs
Tire Size Item # Load Index / Load Range Speed Rating Sidewall Tread Depth (in 32nds) Runflat Tech Features Fuel Effic Features Tread Marking UTQG Tread UTQG Traction UTQG Temp Revolutions Per Mile
More
Max Load, Single (@PSI) Max Load, Dual (@PSI) Overall Diameter Rim Width Range
(Min/Max) Section Width
(On Measuring Rim Width) OE Marking
(Sidewall) OE Code Additional Features Side
(Left/Right)
P205/60R13 54986 86 S RWL 11       916 @ N/A  22.7 5.5" - 7.5" 8.2"
P205/70R14 66748 93 S RWL 12    400 A B 819 1433@35 N/A  25.4 5" - 7" 8.2"
P215/60R14 98659 91 S RWL 11    400 A B 860 1345@35 N/A  24.2 6" - 7.5" 8.7"
P215/70R14 50228 96 S RWL 12    400 A B 803 1554@35 N/A  25.9 5.5" - 7" 8.7"
P225/60R14 53273 94 S RWL 11    400 A B 842 1455@35 N/A  24.7 6" - 8" 9"
P225/70R14 79604 98 S RWL 12    400 A B 785 1675@35 N/A  26.5 6" - 7.5" 9"
P235/60R14 79644 96 S RWL 11    400 A B 829 1565@35 N/A  25.1 6.5" - 8.5" 9.5"
P245/60R14 54322 98 S RWL 11    400 A B 813 1675@35 N/A  25.6 7" - 8.5" 9.8"
P155/80R15 86745 83 S RWL 12    400 A B 842 1069@35 N/A  24.7 4.5" - 5.5" 6.1"
P195/60R15 64472 87 S RWL 11    400 A B 860 1190@35 N/A  24.2 5.5" - 7" 7.9"
P205/60R15 71072 90 S RWL 11    400 A B 842 1301@35 N/A  24.7 5.5" - 7.5" 8.2"
P215/60R15 67797 93 S RWL 11    400 A B 825 1411@35 N/A  25.2 6" - 7.5" 8.7"
P215/65R15 78624 95 S RWL 10.5    400 A B 800 1510@35 N/A  26 6" - 7.5" 8.7"
P215/70R15 72634 97 S RWL 12    400 A B 773 1620@35 N/A  26.9 5.5" - 7" 8.7"
P225/60R15 64148 95 S RWL 11    400 A B 813 1521@35 N/A  25.6 6" - 8" 9"
P225/70R15 67244 100 S RWL 12    400 A B 759 1753@35 N/A  27.4 6" - 7.5" 9"
P235/60R15 54712 98 S RWL 11    400 A B 797 1642@35 N/A  26.1 6.5" - 8.5" 9.5
