Media Blasitng Booths??
FulsGld
Post by FulsGld »
Hey All;
     I need to get a larger sand blasting (or media blasting) booth so I can do bigger suspension pieces(currently using a 55 gallon drum). Also things like fenders and maybe a chassis or two. I don't want the media to fly all over the place (would like to contain most of it). Can any of you all post pictures of your media blasting booths or outfits? I need some ideas. Thanks.
Gary Berry
Prosser, WA
1971 Turista
1969 ManxVair
Member #1112
MyBlueBuggy
Post by MyBlueBuggy »
The booth I used for my pan was actually a converted cargo container. The side door opened up enough to get stuff inside. Problem was it wasn't much more than 20 feet long and got a bit hot inside and not much in the way of ventilation. Afterward you just sweep up the spent media and run it through a sieve and you can reuse it.
