Hello All,
I am trying to find my master cylinder for my brakes. Are the hoods removable on my car?
Thanks all in advance
(I feel like such a dummy asking)
Rick
Where is my brake master cylinder located?
Tom-Kathleen
Re: Where is my brake master cylinder located?
If you don't know, it is not a stupid question, we all had to learn at some point. Lift up the front of the buggy, remove the drivers side front wheel and you should see it near the center of the car, right in front of the brake pedal. You should not have to take off the hood on a "normal" buggy. Tom
Last edited by Tom-Kathleen on Sat Apr 16, 2016 10:25 pm, edited 2 times in total.
read the recommended books I mentioned and you could answer it yourself. the information could come in handy someday. I mean this in the nicest way possible. some opportunistic people may take advantage of you because of this. but have a great day.
Hello All,
I did find the brake plunger (connected to front side of Brake Pedal) and the reservoir for the brake fluid, located on the right hand side, just underneath the hood and behind the front right tire, it appears it gravity feeds to the plunger assy.
I am going to go through this system this Weekend, I am not happy with the line that runs from the reservoir to the plunger, where it goes into the pluger, there is just a rubber grommet with a hole in the middle of it that the filler tube runs through, seems kindof Ghetto to me!!!!
Any Advise?
Thanks in advance,
Rick
Any Advise?
Thanks in advance,
Rick
Be gentle with him. Remember, we all have to fall down a few times before we can walk.
