I took this picture after we exited the canyon. You can tell a bit about the run from the patterns on the tire.
Our suspension got a workout. I had a shock absorber start leaking on the prerun. By the time we got to the bottom of the canyon the shock was dry and groaning.
The pattern was to navigate the rough stretches if you could, park your buggy, and walk back to either record the difficulty on camera or help get a buggy unstuck.
Signs of distress. After the pre-run we made skid pans mandatory for the actual run. This oil was leaked by one of the buggies while it was stuck. Fortunately it was because the buggy was off kilter and not a cracked case.
The actual run is stretches of fairly level stream bed followed by periodic "waterfalls."
Rims were in danger of getting scored and bent.
Note the black on the rock left by tires.
Again, note the tire molecules left EVERYWHERE on rocks.
In the twists and turns up against rocks on aired-down tires one lost pressure, probably due to side stress on the bead. After airing it back held up it held pressure.
The line of buggies waiting for everyone to get through at the bottom of a rough stretch.
Gettin a little three point air was common.
Suspension got a workout.
Looking forward to next year... Sorta.
