Roof Latching
Roof Latching
I'm looking for some ideas to improve the roof latching system, I know there are some out there that have added a more positive latch set up with cables. I'm getting it ready to drive to St. Louis and don't want to worry about the winds going across Kansas.
Tow'd #1 (Hers)
Resorter #19-Fuscia (Hers)
Tow'd #2 (Ours)
Tow'd #1 (Hers)
Tow'd #2 (Ours)
Re: Roof Latching
Put a surfboard on it. We don't even have to latch the roof at all! LOL Tom
- Mike-Presley
Re: Roof Latching
That's what I'm looking for, Thanks Mike & Jon.
Tow'd #1 (Hers)
Tow'd #2 (Ours)
Tow'd #1 (Hers)
Tow'd #2 (Ours)
Re: Roof Latching
What length cable 2' or 3'? do you pictures of the roll bar end?
Thanks
Thanks
Tow'd #1 (Hers)
Tow'd #2 (Ours)
Tow'd #1 (Hers)
Tow'd #2 (Ours)
- Mike-Presley
Re: Roof Latching
Mine is the 2' the manxter looks like 3'. I drilled a hole in the top bars but there is a stainless bracket which comes with the latch
Re: Roof Latching
I think mine are the 3' cables. I used a billet brake line clamp to bolt to the roll cage and just drilled it out to the diameter needed for the latch. The clamp allows for adjustment, but I did add a setscrew to help hold it in place. With the top bouncing around they tended to move a little. I also added some nylon bushing in the hole to quiet the rattles a little. With the rubber pads between the top and cage and the solid latch, my top is solid and quiet.
Re: Roof Latching
Ok Jon, where did you get the rubber disc's?
Re: Roof Latching
Home Depot - They are furniture feet pads or something like that. They are self adhesive and I just stacked a couple together to get the desired height.
http://www.homedepot.com/p/Shepherd-2-i ... /202514361
Re: Roof Latching
Sweet!
Tow'd #1 (Hers)
Tow'd #2 (Ours)
Tow'd #1 (Hers)
Tow'd #2 (Ours)
Re: Roof Latching
I also put a little clear 3m tape on the roll cage where the pads sit to keep it from rubbing the paint off.
