Manxter Style Engine Cage
167luckycharm
Several pics of the bumper and the engine bracket. For those that would like an alternative to the Manxter bumper anyway. The threaded plate fits between the plastic block and on top of the channel section welded to the crosspiece. The 1/2 bolt goes up through the slot in threads up into the plate. When tightened, it will force up against the engine case and be supported by the bumper. The angle strip bolts up against the transaxle mount and the lower bumper rails slide onto the 1" pipes welded at each end. There's enough tension to keep the bumper from sliding off when everything is tightened up. Just my 3 cents...
I hope that price includes all the parts needed to properly mount the Manxter rear bumper. You need a motor mount (mxtr-123-B type 1 or mxtr-122A type II), 2 upper rear bumper brackets (left mxtr-122 -B, right mxtr-122-A), 2 lower rear bumper brackets (mxtr-120), 2 rear bumpers (left mxtr-118 & right mxtr-117) and the crowning part, the rear logo bar (mxtr-119). All bumper parts are stainless, the brackets are plain steel. You also need some small nuts & bolts. It is adjustable lengthwise and offers a lot of exhaust clearance. Tom
