Does laminate flooring really need a mop?
Yes, laminate flooring does benefit from regular cleaning with a mop. While laminate flooring is generally more resistant to moisture and stains compared to other types of flooring, it still requires proper maintenance to keep it looking its best and to extend its lifespan.
Mopping laminate flooring helps to remove dirt, dust, and other debris that can accumulate on the surface. It also helps to remove spills and stains that may occur. Mopping can help maintain the shine and appearance of the laminate and keep it free from grime and buildup.
Additionally, choosing a mop specifically designed for laminate flooring which is gentle on surfaces is beneficial. Microfiber mops are often a popular choice as they are effective at trapping and lifting dirt without excessive moisture.
List of 5 Best mops for Laminate floors
This is a list of popular and highly rated mops for laminate flooring based on their performance and affordability. Here are five options to consider:
- O-Cedar EasyWring Microfiber Spin Mop: This mop features a microfiber mop head that is gentle on laminate flooring and effectively picks up dirt and grime. It comes with a bucket that has a built-in wringer, making it easy to control the mop's moisture level. The O-Cedar offers good value for its price.
- Swiffer WetJet Hardwood & Laminate Floor Mop: The Swiffer WetJet is a popular choice for its convenience and effectiveness. It comes with pre-moistened pads that are specifically designed for laminate flooring. The mop has a spray function that allows you to apply the cleaning solution directly to the floor. It is an affordable and hassle-free option for maintaining laminate floors.
- Bona Laminate Floor Premium Spray Mop: Bona is a well-known brand in the floor care industry, and their spray mop is highly regarded for its quality and performance. It comes with a reusable microfiber mop pad and a refillable cartridge for the cleaning solution. The Bona Spray Mop is a durable and effective option for laminate flooring.
- Shark Steam Pocket Mop: It utilizes the power of steam to clean and sanitize laminate floors. It has a swivel head for maneuverability and includes washable microfiber pads. The mop offers a chemical-free cleaning option and is known for its efficiency in removing stubborn stains and dirt.
- Libman Wonder Mop: This mop is a budget-friendly option that is versatile and suitable for laminate flooring. It has a microfiber mop head that is machine washable and durable. The mop's wringer mechanism allows for easy moisture control. It is an affordable choice without compromising on quality.
And to make it easy for you, TheKingLive gives you the price range of those mops for you to refer to:
- O-Cedar EasyWring Microfiber Spin Mop: Price range: $20 to $40.
- Swiffer WetJet Hardwood & Laminate Floor Mop: Price range: $20 to $30 (starter kit with a mop and cleaning solution included), with additional costs for refill pads and cleaning solution.
- Bona Stone Laminate Floor Premium Spray Mop: Price range: $30 to $50 (includes the mop and cleaning solution), with additional costs for refillable cartridges and microfiber mop pads.
- Shark Steam Pocket Mop: Price range: $50 to $100, depending on the model and additional features.
- Libman Wonder Mop: Price range: $15 to $25
Have you decided which mop for Laminate floors is best for you? You should invest in a mop right away so that you can take care of your laminate flooring soon.
