Bent Spring Plate
Here's an update on what my specific problem turned out to be. The torsion cover plate was warped and it allowed my swing arm/spring plate (what ever it's called) to bow out. I put a new (used) cover on it and the arm/plate now sits on the stop just fine. Bud
Springplates are going to twist during use, no matter if they're swingarm, IRS, adjustable or both. That's why they're springplates, that's what they do. What you want them to do is spring back to original. The straps help keep everything in place. Using good quality german OEM springplates also helps. Unless you find some US made SAW adjustable springplates somewhere, they'll probably be Taiwanese. They'll be adjustable but probably more likely to take a permanent set(bend).
tim morgan
[QUOTE="missionaviator;13280"]
Bud, I saw this method of springplate raising in a guys post on thesamba, and have used it with great success. It reduces the "guillotine" factor considerably. It's way better than messing with the floorjack, etc. If you can't see the pic above, here's the link: http://i170.photobucket.com/albums/u280 ... Medium.jpg[/QUOTE]Good timing,Just getting ready to install my plates,,I like that a lot better then the jack,,Looks like it would be hard to give blood with that set up,,
