Bud's Manx Restoration
marklandon
Re: Bud's Manx Restoration
Post by marklandon »
Hi Joe The Tiger Tow'd has about 14 gal tank so its not a problem and sitting that long is also not a big deal I only wish I had taken photos of the tank when I had it all apart I will have to do it next time so I can make the same tank for the Subi Tow'd
Post by joescoolcustoms »
Cool Mark! I would enjoy seeing it.
atomicmime
Post by atomicmime »
Great job Joe for some long distance cruising! One question: after adding the vent tube on the filler neck, exactly how/where will the vent hose itself be run?
Patrick Cooley
Member #1737
'69 Manx Project
Post by rzeller »
atomicmime wrote:Great job Joe for some long distance cruising! One question: after adding the vent tube on the filler neck, exactly how/where will the vent hose itself be run?
Patrick,
Joe may have other ideas but I plan to couple copper tubing or break line (whatever I get my hands on) to the vent tube using a small piece of fuel line. I'll put a couple of loops in the tubing and then route it directly down (through the body) to the ground below the chassis. There's pictures on thesamba or maybe even on this forum showing the venting options like I'm planning to do. I'll post pictures once its all done.
I think Joe's idea was just to run a rubber line off the vent tube and route it straight down below the chassis. I'll let him comment on that.
Thanks,
Bud
There are several ways to route a vent on a fuel tank. No one way is the best. Bud's idea of some tubing that can be bent into a coil, then routed down is a good.
Most important is the placement of the vent. Never from the tank itself. If fuel get above the vent level, as the fuel expands, it pushes fuel out and starts a siphon effect until the fuel level drops below the vent level.
With Bud's high up in the filler neck, unless he squeezes fuel up into the neck trying to out-distance everyone else, it will not happen.
atomicmime
Thanks for the responses Bud and Joe. The light is beginning to break through... it makes more sense to me now!
Patrick Cooley
Member #1737
'69 Manx Project
The absolute best way to vent a tank is with a vented fuel cap. it will always be the highest point in the tank, no extra vent needed, and it is outside of the buggy "compartment".
Tank is completely finished and ready to go in the buggy.
The inside was cleaned again with a industrial solvent and hot water. Tumbled with a hand full of 3/4 inch nuts inside the tank. Triple rinsed with hot water, (all nuts retrieved). Washed with about 1 quart of Acetone to absorb any remaining water. Then 1 1/2 cans of Damon Red Koyte were put in the tank and tumbled slowly to coat all interior surfaces. The excess Red Koyte was drained from the tank.
After two days curing, the exterior was coated with Damon Over Koyte Plus, twice. The exterior coat does not look all that "bling" like a good coat of gloss paint, but it is a second sealer and protector. My tank has a dent in it from off roading at Big Bear in '14. The dent is about 1/8 inch deep, and the Damon Over Coat was not compromised. The stuff is like concrete to get off of any tools.
So, very well protected inside and out. Let cure until there is no smell on the inside before putting fuel in it, and this tank will last a lot of years. (if fuel is put in before all the smell is gone, the inside coating will stop curing and stay soft, and may slowly dissolve into the fuel).
3680
3681
3682
RedBaronofRedBud
Post by RedBaronofRedBud »
Wow....11 usable gallons! At 50 miles a ride, he can get 5 rides per tank! :lol: :lol: :lol:
Tim and Barb Byrnes
#4236
Team Kermit
Long Haul League
ECVW 14
S2B 15
BTTB 15
joem32380
Post by joem32380 »
and now we sit and wait for updates and installs
Post by rzeller »
joem32380 wrote:and now we sit and wait for updates and installs
It has been a long process. I now have the tank in the buggy and am almost finished re-installing the hood. While I had electrical quick connects/disconnects installed as part of the restoration, I still have to get everything buttoned back in place and circuits tested. I also took advantage of the "down time" by having a face-lift done to my engine tins. They are all finished and the engine back in place and running. I now have a leaking rear axle seal to deal with :x
Since I was having pressure issues with my motor I concluded I needed to add a couple of gauges to my dash. I am a minimalist when it comes to my dash so I've been mulling an idea around on how I can have "disappearing" gauges. I've come up with a little custom idea/project that I'm finishing up. Hopefully it will work like it does in my head.
Lastly, and I just found this out, while Joe did a fantastic job of fabricating my tank without the benefit of having my buggy I have to get up under the dash and prop the rear of the tank up just a bit. The decorative gas filler flip-top that I have mounts by three set screws tightening around the filler neck (it sits on top of the hood). Before the tank re-do I believe the flip-top compressed the hood a little in order for it to catch on the neck. Now the hood seems to have "sprung" back up and I don't have enough neck to attach to. I need to get under the dash and add another layer of foam seal under the lip of the tank to push it up just a bit.
I hope to have everything done in the next week or two. Once I do I'll post pictures of everything and you can see for yourself that Joe is truly a master fabricator. He used every available bit of space in the front of my buggy to get me maximum tank volume.
This is a "before" picture. You can see how much stuck out of the hood:
3414
You can see the set screws in the flip-top:
3578
Bud
Post by rzeller »
Here is the final installment (I hope) of my tank refurb part 2. As the previous pictures and comments from Joe have shown, my tank was custom fabricated and test fitted in a buggy in Joe's shop. It was unknown how well the tank was going to fit when I put it in my buggy. So far (I haven't been able to road test my buggy yet) the only fitment issue I had was the height of the filler neck. I solved the problem by putting another layer of foam seal under the rear edge. This was not a simple task since I didn't want to remove the hood for a second time. It's done now and my flip-top cap fits fine. Below are pictures of how well the tank fits around all the mechanicals of my front end. I will say once again, Joe is an exceptional fabricator! If you want to see all the gory before and after pictures, visit my gallery: http://www.manxclub.com/forum/app.php/gallery/album/44
I will provide a cautionary tale here. To avoid the issues I had (leaking tank modifications), weld all your seams completely. Don't trust any product that claims to be "gasoline rated" to provide a leak-proof seal. With the additives in today's gasoline (and shrinkage and cracking) you will have a problem eventually.
First pictures are the vent hose that is connected to the vent tube on the side of the filler neck. I took the easy route and just vented it to the ground via a pre-existing hole in the chassis.
4159
4202
4186
There is always a constant debate about the best place to put the fuel filter. I decided to run mine in the front since it's an easier location to reach and change.
4188
4199
Joe used every available void/space. You can see how close the tank is to the lifting block on the firewall
4200
4186
I haven't exercised the suspension yet, but I expect that there is plenty of clearance for the tie rods and damper
4189
4199
4197
Other than a Dog Butt ugly finish, it looks to fit perfect. And looks to have plenty of clearance for the suspension. Looking forward to seeing what the final capacity comes up to being.
On the FL trip, some will be coasting, some will be drafting, some will turn the engine off and roll. You will be "why do you guys stop sooo much?"
Post by rzeller »
joescoolcustoms wrote:Other than a Dog Butt ugly finish, it looks to fit perfect. And looks to have plenty of clearance for the suspension. Looking forward to seeing what the final capacity comes up to being.
As soon as I button up a few last things I'll be doing the first fill-up. I'll post the capacity then.
I'll tow those guys to a gas station when they run out :lolno:
Post by rzeller »
Part of the 2016 (part 2) version of the buggy restoration/repair was to give my tins a face lift. One of our local VW guys (young man) has been studying and practicing 70's style metal flaking and painting geometric shapes (think 70's dune buggy). While some of his work is very colorful and detailed, I wanted something a little more subtle. These pictures don't do his work justice. Not only did he put a cool pattern on the tins, he used smaller flake than what was used on the buggy. It sparkles even more than the body does. I asked him to do a matching fire extinguisher also.
To give credit, where credit is due, his name is Jake "Flakey Jake" Martinez.
Here are some of the pictures and detail. I have a lot more in my gallery under the Restoration folder.
4242
4236
4229
4230
4233
