Subaru 2.2L engine with carb
Posted: Mon Sep 05, 2011 5:05 pm
Saw this at BugaRama, a Baja with a 2.2L Subaru engine that had a 2barrel carb adapted to the stock manifold and using some kind of Ford distributor driven of the front of the left side camshaft.
Owner said he did his own work converting it.
Looks to be another way to install a Subaru without having to use fuel injection or crank fired ignition.
There also was a Bug there with dual Weber IDF on a Subaru engine and using the crank fired ignition. Did not get any pictures of it.
