LOOK HERE...NEW idea on clutch cable
Posted: Mon Feb 07, 2011 10:27 pm
by Tom-Kathleen
I ordered one of those for my Kick-Out build. Very high quality, plus he can make a custom length cable for shortened buggies. Tom
Posted: Tue Feb 08, 2011 4:48 am
by Gary1719
Looks like a good Quality product.
Posted: Wed Feb 09, 2011 3:49 am
by towd-dude
I'm a little dense, how do it work ????
Posted: Wed Feb 09, 2011 6:19 am
by Ed-Chenal
Buy two so you have a spare....
Posted: Wed Feb 09, 2011 3:19 pm
by Tom-Kathleen
It works like this - in place of the hook on the clutch arm at the pedal end. there is a "clevis" and a heim joint conection to the clutch cable. The cable is threaded on both ends, one end is stock for the adjuster, the other end for the female heim joint. The cable is very high quality. Nice turning action in place of the sliding action that occurs with the stock hook & eye setup. I am sure you have seen worn out stock hooks. This will also make it easier (without modifying the stock hook) to put the pedal assy in the tunnel. Tom
Posted: Wed Feb 09, 2011 5:13 pm
by louisb
That looks pretty nifty. I think I will order one. Too bad you could not rig up something like that for the throttle cable as that is the one I am usually breaking.
--louis
Posted: Wed Feb 09, 2011 6:23 pm
by dcamomanx
Posted: Thu Feb 10, 2011 12:46 am
by Tom-Kathleen
I mentioned a throttle cable improvement, and something is in the works. Tom
Posted: Thu Feb 10, 2011 3:52 am
by Gary1719
People always seem to figure how to solve problems Don't they. That design would work also. The throttle is something that needs updated also. You guys are right.
