wheel spinning on lift
Posted: Thu May 13, 2010 8:08 pm
I have my dune buggy on a lift and finally got it running thanks to Joseph
when the engine is running, the driver side axle spins like mad, you can stop it with your foot. When its on the ground there is no movement
and everything seems ok.. secondly now and and then when I lift it off the ground I get a very small amount of what seems like trans oil dripping out of the brake drum (I have changed both axle seals and I have new brake cylinders) any ideas?
thanks
thanks
