Brazillian beams
Posted: Mon Mar 19, 2007 7:18 pm
I used a Brazillian "Puma" beam from CB. It is a functional piece with built in adjusters. One big problem though, it sure ain't pretty. The towers have ugly spot welds and the top shock pad is just tacked on. The paint leaves a lot to be desired too. If you have one of these check to make sure that the front of the side intrusion beam mounting clamp fits. I found that there was a bracket that neaded to be trimmed so that the clamp would fit. Oh, and how about those upper grease zirks? I had the beam media blasted and then went to town. Here are some pictures. Olli
