Siggy Manx measurement/dimension needed...
Posted: Thu Nov 30, 2006 11:24 pm
by manxdavid
I just got hold of a Siggy Manx dashboard frame, but I'm missing the oval part that the actual column goes through; it's to the right of center of this photo, the oval piece with the big hole in the middle and the smaller holes at either side...
Could anyone let me know the size of the center hole? I'm guessing it's larger than the size of the column to take one of the rubber grommets in the photo maybe? Am I correct to assume that these are Beetle grommets from where the column goes through the bulkhead? Also would anyone have a spare wheel mounting bracket that they didn't use that they may like to sell? Ta guys...
Posted: Fri Dec 01, 2006 1:57 am
by CairoManx
David, Yes, the rubber grommets are the stock VW ones. My siggy Manx is assembled so I can't measure the I.D. on the flange but its approximately the same as the O.D. of the grommet, down in the grove, if you know what I mean. I believe the flange is just an exhaust pipe flange.
http://www.roadraceengineering.com/flangesandgaskets.htm
Posted: Fri Dec 01, 2006 8:01 am
by manxdavid
I guessed as much, that's what I was planning to use to save making one from scratch. Thanks.
Posted: Fri Dec 01, 2006 5:53 pm
by Classic-Manx-71
David, this is one of two collars that came with my siggy kit.
Posted: Fri Dec 01, 2006 8:18 pm
by Classic-Manx-71
David, these are drawings with measurements of the flanges which came with my siggy kit. Hope they are helpful.
Posted: Fri Dec 01, 2006 9:06 pm
by manxdavid
Brilliant, just what I needed Roger.
