Tow'd U bolts and tow bar, ISO
pongo
Post by pongo »
In search of new long U bolts for the Tow'd. If you've replaced them, where did you get them?
Also in search of a Tow'd tow bar. Looking for a source to purchase a coupler, in the style originally used. Or, if anyone has a bar laying around their garage, and would like to sell it.
Paul
Re: Tow'd U bolts and tow bar, ISO
Post by manxvair »
I got Lori Ann's Tow'd bar from Turn Key Manx, The web page still list's them. I went looking for our old bolts but I haven't found them yet.
Manx Club President
Tow'd (Hers)
pongo
Post by pongo »
Thanks Mike, I saw the bars listed on TurnKey, listed, "not in stock", I emailed couple weeks ago, no reply. I figured, it wouldn't hurt to ask around. I think I can reuse my U bolts, but would replace them, if they're readily available.
Paul
ECV-Keys 2016
Cana-Laska 2016
Manx Club B.O.D.
Iron Buggy Award
ECVW 2015
Long Haul League Award
ECVW 2014
M2746C922S
TF449F912E
M1814D822S
M3234G910E
M3149F912E
1360
Post by manxvair »
I think Brad has been in Australia the last couple of weeks, might explain not responding I'll try to reach him.
If you can find a suspension shop they might be able to make you new U bolts, I had one out here make 1/2" to replace the 3/8" ones that we had.
Manx Club President
Tow'd (Hers)
pongo
Post by pongo »
I will try to find a suspension shop.
Figured he would get back to me when he was available.
thanks Mike
Paul
ECV-Keys 2016
Cana-Laska 2016
Manx Club B.O.D.
Iron Buggy Award
ECVW 2015
ECVW 2014
M2746C922S
TF449F912E
M1814D822S
M3234G910E
M3149F912E
1360
manxter36
Post by manxter36 »
You might be able to find some u bolts designed for 4x4 or trucks. I've also remember someone using allthreads.
Here is link with some info
http://rbcdunebuggy.yuku.com/topic/2309 ... rts-needed
I made a tow bar out of 2 1/4 od thick wall tube that's 42 inch long if I remember correctly. I then welded and bolted on a standard hitch as I couldn't find one that looked like the one Bruce used.
Unfortunately it doesn't retract all the way the originals do.
http://rbcdunebuggy.yuku.com/reply/1483 ... eply-14830
Doran
pongo
Post by pongo »
thanks Doran, I've check out the links.
For the long u-bolts, I located a company in NY, and have submitted the original dimensions to request a per unit price and minimum number per order.
vwmanx
Post by vwmanx »
Paul,
I made a spare set for my Towd from Stainless Rod and threaded the ends.
They are pretty straight forward if youcannot get them made.
