Bud's Manx Restoration
surfnc
Post by surfnc »
I wanted to be first to post a build/restoration thread here but I was too slow. Looking forward to Brian's build with Joe's awesome work
Bud had talked to me about doing some work on his Manx. Front end, wiring and possibly bedlinering his chassis. But once I got into it I found some body damage that needed some attention so the restoration was started.
Here is Bud and Sue in their Manx before I started. (actually at MOTB 2013)
215
(so you can see what it looked like before)
So the first thing I did was take it apart
109
110
111
112
Here is where it all started. The hood had been repaired by a PO and only bondo was used to fill in the crack. This allowed it to flex and showed up as a small bump in the paint. You could see it if you looked at it from the right angle and you could feel it if you rubbed your hand over the area. I told Bud about it and since it had some other cracks he decided to have me repair the damage and paint the body. While I was at it he asked me to do a flake job on it. So here is part of that story.
I ground out all the Bondo and loose fiberglass.
113
I then covered areas with fiberglass cloth and sanded it.
114
I also filled in the hole where the fuel filler was. Then "faired" the areas out.
115
Then came the high build primer.
116
117
The first sanding of the high build primer.
118
127
Then the fairing primer that also acted as a base color coat.
128
Then the flaking.
129
(You can also see the wire tie anchors on the firewall)
130
(flake alone has a rough texture)
131
132
First few coats of clear. (many to follow)
133
135
Then more coats of clear.
136
134
(you can see the "orange peel" texture you get when trying to bury the flake)
About 8 top coats of clear, it is mostly smooth as it "flows out".
137
138
139
Close up of rear fender, looking pretty deep.
Next on to the wet sanding and polishing out, bedliner and wiring.
Vince
Siggymanx33
Re: Bud's Manx Restoration
Post by Siggymanx33 »
Looks great Vince….Is that the same color as yours?
Post by joescoolcustoms »
Wow! Another super nice Flake job. Looking forward to seeing it in person.
surfnc
Post by surfnc »
Thanks Dave, it is actually 52P Ocean Spray. It is close but has more blue in it than mine.
Looking forward to your Limetruse Manx!!
Thanks Joe, looking forward to all of your projects.
Vince
Post by rzeller »
Vince and I have been friends for a while now but we've never had a business relationship before. I've got to tell you that he makes great recommendations and will execute your plan exactly as you want. Not to mention (and as you can see) does exceptional work. I can't wait to get the buggy back and put the new motor in it - all in prep for the trip to Niagara Falls in June.
surfnc
Post by surfnc »
Thanks Bud! You should be able to get that pin in your Manx. :wink:
Wet sanded and buffed out the hood today.
Not the best picture. Started with 600 grit then 1000, 1500, 2000.
241
Then buffed it out with a wool pad and polishing compound, finished up with a foam pad and "swirl" remover.
245
243
244
242
It is difficult to get a picture of flake that shows it properly but this should give a good idea.
I have to go over the body once more then on to attaching the new dash.
Vince
Cool! A long haul dash on a short haul buggy. Who would have thought? :shock:
Post by rzeller »
joescoolcustoms wrote:Cool! A long haul dash on a short haul buggy. Who would have thought? :shock:
Yes Joe Wheeler you are correct. A part of our buggy earned it's long haul status before it's owners. That all changes this June. I'm doing the east coast version of the Buffalo Shuffle in my new gem and will be driving to the falls. Better bring your sunglasses if your anywhere near me! :mrgreen:
abgiles
Post by abgiles »
Bud,
I'm a little confused, or I'm missing something. What's the east coast version? If my class starts later than planned, I'll be driving from Ga, and it's 1005 miles for me. I guess I need to search around a little more to see what groups are heading where.
Vince,
That's some incredible work. Can't wait to see this one!
(Gunther) Manx 2 # A0202A035E
Tow'dster # TF530G913S
Club Member # 4436
surfnc
Post by surfnc »
Brian,
Thanks for the kind words! The Bud "long Haul" thing is kind of an inside joke at Bud's expense. So he or Joe should explain it.
Vince
abgiles
Post by abgiles »
Vince,
I've been informed. I just thought Bud had found a way to stretch the distance from Wilmington to Niagra a bit to get his pin. Love that this ribbing is still going.
Club Member # 4436
He has been the "Bud" of many jokes, and has been very good about it. If I get to make Buffalo, I want to be the first to shake his hand once he gets his Long Haul Pin.
I am thinking Bud and Sue will be running up the coast from Wilmington into NY, then turn West to Buffalo. That will stretch it out and make the 1000 mile one-way mark. :clap: I think it will also include some very sweet sight seeing, a run with Farmer John and Paul on a curvy trail through some mountains.
Post by rzeller »
joescoolcustoms wrote:He has been the "Bud" of many jokes, and has been very good about it. If I get to make Buffalo, I want to be the first to shake his hand once he gets his Long Haul Pin.
Joe is correct, I'm hugging the east coast up to my hometown in NY. Then meeting up with at least two others, Farmer John and Paul, to complete the trip to the falls. Coincidentally, it IS 1000 miles :twisted:
abgiles
Post by abgiles »
I'm excited for you Bud. Maybe then they'll stop dogging you, but I doubt it. Depending on my class schedule, there are a few of us that would like to make the trip from the SE corner of GA (Kingsland) and get our pins too. It's 1005 miles from my house to Niagra, and I'm sure we'd detour around some.
Once we get closer to determining if we can go, we will definitely see about timing for meeting and joining you guys on the way.
Right now, I'm slated to start my schooling at the beginning of that week, and am not allowed to miss any days. There's already talk of shifting the schedule, so we'll keep you posted.
Club Member # 4436
Siggymanx33
As we get closer, I'd like to see about tagging along for the last leg of the trip. I'd be leaving from my house in the Poconos which is about an hour south of your hometown….I think.
