Forum Nickname
Posted: Fri May 07, 2010 2:25 pm
by louisb
I notice that when I post it attaches .rcbdunebuggy after my forum nick (louisb). Is there a way to remove this? I tried looking in the account settings but did not see how it could be done.
Thanks,
--louis
Forum Nickname
Posted: Fri May 07, 2010 6:06 pm
Louis
Just go into your profile and then "EDIT"
look at the top where you name is and it should be quite easy
Gene
Forum Nickname
Posted: Fri May 07, 2010 7:10 pm
by louisb
Hi Gene,
Thanks for the tip but it does not appear that you can change the nic, just your actual name. I dont know why it is listing me as louisb.rbcdunebuggy on the forums.
Thanks,
--louis
Forum Nickname
Posted: Sat May 08, 2010 12:00 am
by MyBlueBuggy
Louis,
It reads that way because your account was made as a local profile for the RBC forums. I've looked into this and unfortunately you cannot eliminate it. However, registering an account at the yuku home page will give you what's called a global account and not have the forum suffix attached.
