Transaxle Parts
Transaxle Parts
My pan is a 1956, which originally had a split case tranaxle in it. The previous owner converted it to a newer model full sincro swing trans. In order to make this conversion, you need to change the nose cone to an early bus swingaxle for the shift linkage to match up. I need a new nose cone, and hockey stick, but have been unable to find what I need via web search. The nose cone is 211 301 211E. The hockey stick is chewed up from somebody running it too long with bad bushings. Anybody have any suggestions?
I got a new replacement bus nose cone from Long Enterprises. The hockey stick is also available from them. To make the future replacements easier to obtain, I used the bug hockey stick with the bus nose cone. The shift rod was slightly offset prior to welding, to compensate for the difference between the two styles of hockey sticks. It is set up for the later bug version with the setscrew straight up. I figured the bus hockey stick would become hard to find someday. John.
