Mirror mounting
Mirror mounting
I bought 2 mirrors that mount to the windshield from Bugshields but I'm a little confused how to mount them. When I try to tighten the mirror arm, the threads of the arm turn and go thru the 2 piece bracket and will damage the windshield frame. I must be doing something wrong. They came without instructions and I'm confused. You can see how the threads come thru in the photo. Thanks, Tim
Hey Tim sorry about your mirrors there the ones that give Buggy Dudes troubles, if you can't get someone to help check out this guy http://www.bandkmfg.com/ he makes them right here in Calif. they're Hot Rod Quality super nice.
1969 Sand Rover T pickup
1973 Thing / Yorba Linda,Ca.
[QUOTE="tgodber"]I bought 2 mirrors that mount to the windshield from Bugshields but I'm a little confused how to mount them. When I try to tighten the mirror arm, the threads of the arm turn and go thru the 2 piece bracket and will damage the windshield frame. I must be doing something wrong. They came without instructions and I'm confused. You can see how the threads come thru in the photo. Thanks, Tim[/QUOTE] I run the same mirrors you have. You need to turn the nut on the mirror out to set the depth of the stud so it won't contact the windshield frame, Make sure you use loctite on them and you won't have any problems with them.
