Adjustable Beam Questin
I have an adjustable ball joint beam on my Siggy. I am thinking of raising the front end some. Will this effect the alignment (toe)?
Any time you make chassis adjustments you should have the alignment checked. It sort of goes hand in hand with raising or lowering the front ride height. This sort of leads me to another question. When checking the toe on your buggy should you have the fuel tank filled to the top, half way, or nearly empty?
