Front suspension
Front suspension
I think that I have a leaf broken on the front end. I have heard some people talking about cutting some of the leaves in order to soften the ride. Since this has never been done I was wondering if I should just cut the leaf that is broken on the other side or replace them and then cut them. Also how difficult is it to do this and can you just cut one leaf say on the top bar and leave the lower bar alone or do I need to cut the leaves on both?
Whatever you do make sure that you put the leaves back in the same relationships that they had when you took them out. Label them carefully as to which is the left or right side and which way is to the back. A leaf which has been flexing in a certain way does not like to flex the other way. The same is true of the rear torsion bars.
