It is currently Fri Feb 23, 2018 7:43 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: Sun Jan 17, 2016 7:19 pm
Offline
Images: 101
Looks like it will work well for supporting the radiator.
_________________
Top
 Profile Personal album
PostPosted: Sun Jan 17, 2016 9:22 pm
Offline
If anyone needs the file I would be glad to share. I did some rough test pieces and they fit well, so these should go in nice. I will update on details once the are all prepped and in.
Top
 Profile
PostPosted: Wed Jan 20, 2016 4:26 pm
Offline
So here it is all bent over, dimple died and ready to weld in place.
Those weld into here and we should be ready to mount the radiator using rubber isolators.
Top
 Profile
PostPosted: Fri Jan 22, 2016 6:50 am
Offline
Food for thought for anyone else trying to figure out radiator wing mounting.
Top
 Profile
PostPosted: Fri Jan 22, 2016 6:54 am
Offline
Images: 203
How is the radiator held to the supports?
_________________
So-Cal
Manx Club President
Tow'd (Hers)
2013 Sea to Sea Safari
2014 Manx Baja Tour
2015 NORRA 1000
2015 Shuffle to Buffalo
2015 SoCal cruise to Topaz II
2016 West Coast to No Coast-No Coast to Topaz-Topaz to SoCal
2017 NORRA 1000
2018 NORRA 1000
Top
PostPosted: Fri Jan 22, 2016 3:48 pm
Offline
The radiator I bought had some 90* tabs welded to the sides. They sit on the bent sheet metal with rubber isolators in between.
Top
 Profile
PostPosted: Wed Mar 02, 2016 7:04 am
Offline
Another pair made. Going to try and adapt these to manxter 160. The read support on the manxter is much different than the dual sport. We will see how it works out.
Top
 Profile
PostPosted: Mon Feb 27, 2017 7:44 am
Offline
IF ..... u are going to try and put them on a Manxter 2+2 make sure that you test fit with the radiator for sure BUT also make sure you have the engine in and mounted with the intake and TB etc on it. The clearance under the rear of the Manxter 2+2 is MUCH lower than the DS.
For example my Ej Series Buggy Exhausts does not fit a Manxter 2+2 with rear wing as the muffler touches the rear wing. In a DualSports it is no where near and I never thought it would hit. I have also had issues clearing the TB and Manifold when I setup using measurements as opposed from doing complete mock up.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
