It is currently Fri Feb 23, 2018 7:42 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Tow'd Gas Tank
PostPosted: Mon Jun 22, 2015 5:19 pm
Offline
Images: 5
My original Tow'd well casing gas tank has a lot of surface rust. I did not want to go through the hassle of machining and welding in a fuel sending unit bung and having the tank interior recoated. I was able to source a spun aluminum center fill gas tank with dual outlet sump, fuel sending unit bung, and 3/8 inch vent for $247.00. Same diameter and length as the original. I will post pictures once I receive it. Keeping the old tank.
Top
 Profile Personal album
 Post subject: Re: Tow'd Gas Tank
PostPosted: Mon Jun 22, 2015 6:34 pm
Offline
Images: 4
Care to identify the source?
We are in a similar situation, ours is toast too. Speedway have aluminum or ss units but none with sending units.
_________________
Rosemarie and Paul Hill
Morrisburg, Ontario
Canada
613 330 4862
Member #4502
Top
PostPosted: Sun Jun 28, 2015 7:52 pm
Offline
Images: 5
The source for the tank is Sandstorm USA. They are located in Kansas. the email address is sandstorm_usa@hotmail.com ATTN: Lisa. Tell her you want the same type tank I ordered. She will provide you with drawing. 35 inch wide, 10 inch diameter, flat indented sides, sending unit bung, sump with dual 3/8" npt outlets, 3/8 npt bung vent, etc. I ordered it with a 2 inch filler neck for a hose versus the standard one with a screw on cap. I plan to use a custom filler assembly versus having the filler neck stick out. The only issue is you will have to create a mounting bracket for the tank straps. I was advised not to weld aluminum right angle material to the tank due to possibility of stress cracking. Still thinking whether I will create brackets on the torsion bar tunnel or weld right angle material to the sides of the frame and run cross bars across the chassis. The center to center mounting dimensions of the tank straps are 4 7/8 inches. My tank is shipping this week. For some reason spell checker is hi lighting the email address. It is sandstorm_
You will need a sending unit with the proper ohms for your compatible fuel gauge.
Hope this helps,
Tom
Top
PostPosted: Tue Jun 30, 2015 1:45 am
Offline
Images: 4
Thanks Tom.
Sent an email today.
_________________
Morrisburg, Ontario
Canada
613 330 4862
Member #4502
Top
PostPosted: Mon Sep 26, 2016 4:48 pm
Offline
Images: 4
Thanks for the help Tom but we're out of the tank loop, at least for now. We found another Tow'd after we realized our frame was beyond help. The po had replaced the tank with an aluminum one.
Problem solved!
_________________
Morrisburg, Ontario
Canada
613 330 4862
Member #4502
Top
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
