My Australian / US Tow'dster
Aussi Aussi Aussi !!! Tom
Re: My Australian / US Tow'dster
The front fenders on my Towdster starting to take shape to cover the wider stance and longer up travel . These will be strengthened up and cleaned up and then us3ed as plugg's to make a mold and make some new fenders .
And if they don't look that much different to stock Towdster guards ( thats a good thing by the way ) the definetly are as they all but cover my 6' 3" width of the front end
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/10622320_10204251289391651_726308154_n_zps973d0399.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/10620955_10204250691776711_384228800_n_zps1176bdc6.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/10622321_10204251289231647_1625316742_n_zps3c1333e9.jpg)
Bit more done lately and some other stuff starting to get finished off .
The rear infill panel and modified Trimil Bobcat exhaust .
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/10647722_10204361850955621_576176323_n_zpsf9ca143a.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/10660493_10204361788834068_1512783309_n_zpscb1c6e5b.jpg)
The front skid plate which will have a 250mm x 220mm hole cut into and ducted up to my engine oil cooler to give it good clean cool air
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/10637598_10204361891276629_1890520761_n_zps5034cb3c.jpg)
The modified Jamar brake and clutch pedals and Pauls custom made throttle pedal which will keep the floor clear
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/10579718_10204361851475634_1347131023_n_zps27a481c2.jpg)
The centre consul with jamar X shifter
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/10656494_10204361874556211_1261089398_n_zps9dabecce.jpg)
Andrew, some of the pictures have been lost in the transition to the new forum.
- vincent9993
Actually Mike, those picture links were already broken before the conversion. I think the source of the pictures may have changed. Hopefully Andrew can restore those.manxvair wrote:Andrew, some of the pictures have been lost in the transition to the new forum.
Thanks Vincent, Andrew re-post those picture!
Ok it's been a while again since the last post , but still moving forward , will let the pictures speak
Designed , cut , folded and fitted a dash panel
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild039_zps53a7f70e.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild040_zpsabbce0e6.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild042_zps802669a6.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild045_zps77d001fc.jpg)
Mounted the oil cooler , it's a Towd , space is tight , and i didn't like the idea of the oil radiator drawing hot air off the top of the gearbox and or the hot from said radiator getting drawn into the cool air inlet on the fan shroud
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild043_zps59061edc.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild044_zpsee91e18b.jpg)
Cut and folded up some headlight brackets
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild049_zps5962b47d.jpg)
The alloy fuel tank in place , with the cut out area in the bottom to get around the hydralic lines of the fiddlers
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild057_zpsbe49df42.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild058_zps894dbc67.jpg)
MMMMMMMMMM Starting to get the final items welded out
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild061_zpsdba36664.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild063_zpsf72e7c21.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild064_zps4478c4e6.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild065_zps7954764a.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/TowdBuild067_zpsf40ac18b.jpg)
Pull it apart , put it together , sleep , and repeat
Yes it's back together again at the moment as Buggy Brad has been back over here in Oz among other things wiring a lot of the car for me
Dash is pretty well done although i think i'll drop the second skin around the speedhut guages , it was just an idea and the final one was to be cut out of alloy and polished
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20Build%20003_zpsd4clghqs.jpg)
Wiring everywhere and being a towd space for items is fast running out , with the fuse box , 100 amp breaker , cig lighter , icom 440 uhf radio , (yes we can run UHF here in Aus) and the balast for the LED light bar
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20Build%20007_zps4dd3vlji.jpg)
Switching for the following from left to right , Wipers , Horn , steering column , Interior light , LED light bar , Headlights with ignition underneath
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20Build%20008_zpsylk6wvhf.jpg)
Remote oil filter with sensor fitted to activate thermo fan on the oil cooler
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20Build%20013_zpsua5nvjfj.jpg)
And how it currently sits in full , yep theres plenty still to do , but it's getting there finally
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20Build%20015_zpscjgu3ty6.jpg)
Except for the steering wheel on wrong side Nicest Towd I have seen....WOW
Anyway a bit more progress of late , thanks to my fiberglassing buddy , the plug is finally done to make the mould for my new rear fenders
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20Build%20001_zpssdyno2ns.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20Build%20002_zpsizpndkky.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20Build%20003_zps867tupom.jpg)
- PowersBuggies
Lookin Good!
Craig and Rebecca
Manx Club #3634
66 Manx/68 Towd - His
67 Tow'd/67 Manx - Hers
67 Dune Buggy - Our Build
69 Empi Imp - Korinne
***ACCOMPLISHED!***
Manx Club #3634
***ACCOMPLISHED!***
Did you get the Subaru fitted in it yet?
Manx Club President
Tow'd (Hers)
Manx Club President
Tow'd (Hers)
The rear fenders fitted up
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20rear%20guards%202_zpslkqe1xe7.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20rear%20guards%201_zpscljbhojx.jpg)
Front fender plugs for the moulds fitted up to check fit etc and all looks sweet
Grabed a few photos for you all while they were on
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20build%20031_zpsp6giensg.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20build%20032_zpspc3lsxb6.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20build%20029_zps6b7lu2tp.jpg)
![Image](http://i1185.photobucket.com/albums/z342/OzTowdster/Towd%20build%20028_zpsbrdfghow.jpg)
- PowersBuggies
Looks like it's coming along! Bringing it MOTB with Todd this year???????
Craig and Rebecca
Manx Club #3634
***ACCOMPLISHED!***
Manx Club #3634
***ACCOMPLISHED!***
