1600sp autoclutch to 67bug tranny help
Hey all, Newbie question for ya. I picked up a 1600sp motor from a '70 ghia today. I want to bolt it to a 67 swing axle for use in my clone. What do I need to mate these two components? Do I just buy a 1600 flywheel and clutchpack? or is there more to it? Also, I have a 1200 flywheel. will that bolt onto the 1600? Thanks in advance.
joemama
Post by joemama »
I believe all you will need is a 200mm flywheel, not from a 1200, thats a 180mm, the appropriate throwout bearing for a 67 swing axle, as well as the corresponding pressure plate and disc. Any VW parts house should be able to sell you the right parts. You will also need a new gland nut and washer.
