Floor pans
Floor pans
I was wondering if anybody knew if their was a company that sold already shortaned floor pans?
Nobody makes shortened floorpans.
flaboyjim
Post by flaboyjim »
There are several companies that make 80.5" Chassis for buggies. They have the original rear torsion welded in, but everything else is tubular steel. They are available with either king pin or ball joint front ends and swing axle or IRS rears. I am using a Berrien Chassis in my build - a 60s Manx Clone. but there are others.
Pans
Don't mess with the lite pans get the heavest ones you can buy ---What my welding guru does is he install the pan ,then cuts the whole thing the 14 1/4 inchs works on the ones I've had cut down like a charm Richard
