#33 going in the shop (advice)
I baught my oil filter mount from Pete like the one pictured. He went one step further and made me one to fit the Meyers exaust without having to remove the preheat flange. It fit perfect and looks great too! I went on the Lone Pine thill seekers run with my Manxter and had no problem with it. I highly recommend getting one.
[QUOTE="allen pierce"]And, you can find them at almost any after market VW place. Look in the DB&HVW's magazine. I got this one from Kustom 1 Warehouse.[/QUOTE] I guess I'm a little behind the times. I have been using this style breather for years and the only place they were available was from CB perf.. It seems as if someone must have started reproducing CB's breathers? ![Surprised :eek:](./images/smilies/icon_surprised.gif)
I too got mine from Pete but had it powder coated. It's seen here with the Gene Berg full flow set up and a System 1 oil filter.
http://i5.photobucket.com/albums/y190/bountydm/OIL5.jpg
I have since pulled the lines away from the exhaust.
![Image](http://i5.photobucket.com/albums/y190/bountydm/OIL4.jpg)
![Image](http://i5.photobucket.com/albums/y190/bountydm/OIL3.jpg)
Dean, Are you going to plug up the end of your fan shroud heater outlets? That might direct more cooling air over the cyclinders. I was at first thinking you could use those rubber plumbing 'caps' with an aircraft clamp, but there's probably something better out there. I guess we're all members of the "Pete's Oil Filter Bracket Club". I'll make up some membership cards. :laugh1:
