Deitz lower base
Deitz lower base
I just found what I believe is a Meyers manx 1 it has deitz headlights and one of the really thick mounting bases are missing any ideas where I can get this ?
Re: Deitz lower base
Regarding the base, is the one you have a CAST piece? If so, you might try swap meets and find some old rusty dietz buckets. The newer style is a stamped deal...
You could either have one machined or machine one yourself if you have a lathe.
Place a WANT ad in the classified section and also a WTB on the SAMBA...take pictures of the one you have and include that in your ad.
Good luck
Good luck
