Error: NOT an Early Squaretail manx sold in Georgia
Posted: Tue Jan 27, 2015 4:25 am
by vwmanx
Does anyone know who bought the early square tail manx near Atlanta within the last few days>
Yellow body, mid 50s pan
The buggy was in the sellers family for 44 years...
I posted over on FB as well...just hoping it went to someone who will know not to chop it up.
Re: Early Squaretail manx sold in Georgia
Posted: Wed Jan 28, 2015 8:43 pm
by abgiles
Posted: Wed Jan 28, 2015 9:04 pm
by CairoManx
They had tubes from the earliest floorpan Manx, but they didn't start using lifting blocks until after they had tags
Posted: Wed Jan 28, 2015 9:10 pm
by abgiles
CairoManx wrote:They had tubes from the earliest floorpan Manx, but they didn't start using lifting blocks until after they had tags
Thanks for that bit of information!
So do you see tubes on this one? I'm not sure if those are them or not on the sides. Mine look different, but it's a later model Manx. Also, the supports under the tail, are those original?
Posted: Wed Jan 28, 2015 11:25 pm
by vwmanx
Brian,
In the one picture it looks like the tube may have been cut out. The rear support flanges are definitely not Meyers...that is not to say they could have been added in (just saying). The same area on mine has curled ever so slightly...and it is VERY flexible due to the thin layup.
There also is no sump bump for the brake line bracket in the spare tire sump. If this is not an early manx, a mold was taken from an early car.
The thing that made me strongly suspect it to be a Manx was the ABS dash and the dash frame and the lack of sump bump.
I had asked him for pictures of the windshield frame but he never responded...
The final verdict on it would be a first hand inspection. These bodies were all hand laid up and most are by most standards extremely thin.
As far as determining whether or not it is an original square tail manx, the details would be:
square tail
standard bump on hood
tubes under fenders (made from vacuum hose)....I noted on the Tejon manx and mine that the hoses have mostly deteriorated but you can feel the ribbing molded inside the tube.
ABS dash
strap windshield windshield frame
no bump in the spare tire sump for the hydraulic brake line bracket
thin lamination...and hand laid up with fiberglass cloth..not fiberglass mat.
I have been wrong before (gasp). I hope that we find who bought it...we can get more information then.
If it turns out to not be an early sq tail, it is identical in almost every detail and would be very difficult to tell without close inspection.
Posted: Thu Jan 29, 2015 12:21 am
by abgiles
Thanks Chris! Nice to know the detailed information!
Posted: Thu Jan 29, 2015 6:25 am
by CairoManx
I have a square tail clone sitting on my back patio now. It has the exact same gussets under the rear skirt.
Posted: Thu Jan 29, 2015 1:30 pm
by vwmanx
Does it have the abs dash and dash support?
Posted: Thu Jan 29, 2015 10:04 pm
by CairoManx
It has a steel dash support and a fiberglass dash that looks identical the Manx dash.
